sway bars
Old Jun 20, 2010 | 08:13 PM
reloadx510's Avatar
Cool sway bars
i was looking on a web site and there were 3 options
Front and Rear Kit $323.95
Ships between 06/21/2010 - 06/22/2010
  • Bar Diameters: Front 35mm - Rear 21mm
Front Bar $201.95
  • Bar Diameter: Front 32mm
Rear Bar $154.95
  • Bar Diameter: Rear 25mm
my question is wats the difference between the 35mm and 32mm fronts and 21mm and 25mm rear? does this mean the shorter bar gives more anti roll? or it doesnt make a different? i understand its an option if somebody is looking to replace either the front or the real only. learn me please
Old Jun 20, 2010 | 08:40 PM
tripwire1124's Avatar
holy crap, just go to a bone yard and grab some off a Z28. unless you already own a z28 im sure this way will be much cheaper than that and have little difference between them.
Old Jun 20, 2010 | 09:25 PM
This is whats on the SS and LE1's. You do not want to get a hollow bar from the junk yard cause they tend to crack with age and use.
http://cgi.ebay.com/ebaymotors/93-02...item45f2d35a60
http://cgi.ebay.com/ebaymotors/93-02...item1c12e92f69
Old Jun 20, 2010 | 11:07 PM
Massey's Avatar
you will prolly not notice a 3 MM difference in the diameter. NASCAR drivers might in their racecars but that is about it. Solid ones are better for long life and are pretty cheap.
Massey
Old Jun 21, 2010 | 12:20 AM
libertyforall1776's Avatar
For arguably the best option, go for the StranoParts swaybars for weight savings and performance:
http://www.stranoparts.com/searchbym...=126&ModelID=7
Old Jun 21, 2010 | 01:03 AM
The link you provided mentioned a change in SS sway bars in 2001 -- do you know what the change was?
Old Jun 22, 2010 | 05:12 PM
bcartman2's Avatar
the later SS bars are better from what i am told they are thicker but i dont remember how thick
jkeaton
Sep 5, 2012 04:31 PM
TheArtfulLodger
Apr 26, 2012 04:10 PM
3800camaro
Mar 12, 2011 01:58 PM
maudyZ28
Mar 29, 2010 05:30 AM
