STP Products
Old Jun 3, 2013 | 09:19 PM
thatdude305's Avatar
Default STP Products
STP fuel and fuel injector cleaners. Do they even do anything is it worth using. I only get synthetic oil changes and change my fluids on the regular??????
Old Jun 4, 2013 | 07:44 AM
MKCoconuts's Avatar
I can't say much on the STP stuff even though I get free samples every six months since I just stick it my four wheeler. But never noticed a difference with that. Have used Lucas "Tune Up" in a bottle and their deep clean stuff. Spark plugs look cleaner after using it and I've seen an increase of 2 mpg. SeaFoam is real nice to use if you stick it through a vacuum hose.
Old Jun 4, 2013 | 12:52 PM
if your conserned or you have over 100k miles i would recomend the injectors be cleaned and flow tested at a good injector shop. not that costly if you remove and install them yourself. the injectors can be within factory specs and not be matched very well.
Old Jun 4, 2013 | 01:34 PM
As preventive medicine, maybe, but don't expect a cleaner to "fix" a problem. Tried that once with Lucas injector cleaner. Physically removing and soaking a clogged injector did the trick, where 3 tankfuls using the cleaner didn't help in the least.
BeerBottleBrown
Apr 12, 2013 09:11 PM
project blackjack
May 26, 2010 10:23 AM
kyphur
Apr 21, 2009 10:57 PM
94Red
Dec 1, 2007 07:36 PM
