Starting Issue
Old Mar 18, 2012 | 09:27 PM
aappss01's Avatar
Exclamation Starting Issue
Alright im having some trouble starting my car. The car is a 95 z28. When I get in the car (without inserting the key) everything works. I can toggle lights and everything but as soon as I insert the key to start the car everything cuts off. No power, no radio, no lights, no gauges, and I cant start the car. However if I sit in the drivers seat and rock back and forth a bit the electronics will flick on and off like 6 times and then finally come on and stay on. At this point I can start the car perfectly and It will drive fine. Ive check the battery connections, the alternator connections and the starter and ignition fuses. I also check under the steering wheel to check for any obvious ground issues. Im really at a loss here so any help would be appreciated guys. Thank you!
Old Mar 19, 2012 | 07:11 AM
Old Mar 19, 2012 | 08:13 AM
If it's the VATS causing this, the "security" light in the dash will be lit. Is it?
Old Mar 19, 2012 | 09:53 AM
aappss01's Avatar
Alright turns out it wasnt the security system like I thought, I poked around the engine bay some more this morning and saw that the battery ground next to the stock terminal box was corroded. So I replaced that and all is fine now!
MsElla
Jun 29, 2013 11:58 AM
Palmbach195
Feb 4, 2011 06:59 AM
NovaBrad
Jun 28, 2010 03:14 PM
Baseballchris05
Mar 13, 2009 02:27 PM
axissean
Nov 14, 2006 10:21 PM
