smelling coolant
#21
I didn't flush it like I had said I was, I think I found the leak. I jacked it up and was underneath and saw a drip coming from behind the lower right pulley not on the hose. I couldn't see it too well cos of the position but I stuck my hand there and it was wet but the hose was dry. I think I may have it take it to a shop tho i cant afford to right now
#23
well on my 3.4 theres a rubber cap on that port right below the radiator cap. it tends to crack over the years. not sure what model you have. that still doesn't solve the problem in my opinion. esp. you saying everything looks dry. it would be all over the inside of the hood. have you checked the hoses to the heater core. any leaking on the firewall. are you getting good heat from your vents is your passenger side carpet wet.. white smoke out the exhaust(unusual amount) does the car run temp on the high side. check behind the oil pan and converter shield for rear seal failure. back if the lower intake manifold for gasket failure. is the rtv still good back there. just a couple of thoughts
#25
Sorry to high jack your thread.
I had a coolant leak on my RS and smelled coolant -- was the timing cover gasket -- now fixed.
You should get some super flush and clean out your cooling system - do it a 2nd time if its really gunky... Should probably replace your thermostat while you're at it... You should be ideally flushing your coolant every season if using the green coolant and less frequently if using the GM spec'd DEXCOOL orange coolant (see Owner's Manual)...
KuwaitCamaroSS
02-13-2009 09:58 AM
