slow to start not sure why
Old Nov 17, 2012 | 07:45 PM
vats/anti theft will not allow the starter to engage. i would get some new plugs and a fuel filter. if you just got it go through all the fluids and change em. look the brakes over change fuel filter, spark plugs, maybe have the injectors cleaned and flow tested.
Old Nov 17, 2012 | 07:52 PM
wayne242's Avatar
Originally Posted by mutlyi4
ok but if this were the case my fuel pump would not engage right?? becuase it kick on fine with key on and primes like it suposed to almost seems like no spark (wich as i said befor i will check tomorrow) as it just turns over forever unless i release the started then try again then fires right up
Yeah, it would shut the fuel pump down. Check the spark in the morning when it's doing this, and let us know the results.
Edit: Like craby said, it "should" shut the starter down also, but i have heard not always( could be just hear say). Mine shuts down both when my buddy tried his camaro key in it.
Old Nov 18, 2012 | 09:50 AM
mutlyi4's Avatar
i have weak spark the spark is red not blue in color is this normal for these??? if not what could cause this
Old Nov 18, 2012 | 09:58 AM
old plug wires, weak coil, weak voltage to coil, opti. i would start with new plug wires and plugs.
Old Nov 18, 2012 | 10:18 AM
mutlyi4's Avatar
ok thank you i will also change the coil while im there as i have a good used one laying in the garage
IROC87
May 15, 2015 04:55 PM
MarinaBlue67
67-69 V8 Tech
12
Aug 1, 2013 12:49 AM
fluger77
Sep 5, 2007 12:24 AM
94CamaroSFI
Dec 7, 2006 06:36 PM
