shifter question??
Here you go, M16 X 1.5. Take a look at koolknobs.com, bruce there is a great guy and does some awesome stuff, should get my green with black rally **** in the mail sometime soon.
I had the same problem. I couldnt find any sizes for a new shifter ****. So I went out and bought a shifter ****.(It obviously didnt fit). So I took a hex bolt and in this case it was a 7/16 bolt and then I found a bolt that fit pretty well to my shifter. In this case a 5/8 bolt. So I screwed the 7/16 bolt to my new shifter ****, then welded it to the 5/8 bolt. I can now screw on my new shifter **** with no problems.
yes i do belive that big leather ball is stock,i drive a stock 94z28 in1995 on a test drive @ a dealer.that was one of the things i didn't like about the Z i drove mustangs (hurl) before and the shift handle felt better+the z i drove had real low oil pressure at idle and that scared me into not buying the car,ya i found out later thats the way they are
the hurst ss shift handle is nicer,wonder it should fit right on?
