Shaky shift knob problem
Old Jan 20, 2018 | 05:26 PM
ahaas2011's Avatar
Angry Shaky shift **** problem
I have a completely stock 2000 Z28 w/ T56. I have the hurst shifter, and i noticed the shifter was tight, but the gears have play in them, lots of play. I know this isn’t normal. The shifter is nice and stable in every gear until i let it go at wide open throttle. Then, the shift **** wobbles and shakes everywhere. I haven’t tested this out past 2nd gear but I know this is not normal. I’m assuming it’s the shifter cup bushing, but my shifter isn’t loose enough for it to be that. So i’m unsure. Does anyone know what this might be. Here’s a link to a video of it happening in first gear...
Old Jan 21, 2018 | 12:19 PM
check your transmission mount an see if its busted. because of the weight on it, its not easy to tell if its broken. best to get a floor jack under it for support so you can tell by taking the crossbar lose to let you see if its broke. can just jack it up but risk breaking it if to much pressure is put on it.
95z28man
Jul 29, 2014 02:23 PM
vXIcetreyXv
Feb 11, 2011 12:43 AM
tipdrip215
Mar 25, 2008 03:42 PM
96Camaro3800II
Jul 21, 2006 05:32 PM
sewerrat
Jul 13, 2005 05:46 AM
