Shaky shift knob problem
I have a completely stock 2000 Z28 w/ T56. I have the hurst shifter, and i noticed the shifter was tight, but the gears have play in them, lots of play. I know this isn’t normal. The shifter is nice and stable in every gear until i let it go at wide open throttle. Then, the shift knob wobbles and shakes everywhere. I haven’t tested this out past 2nd gear but I know this is not normal. I’m assuming it’s the shifter cup bushing, but my shifter isn’t loose enough for it to be that. So i’m unsure. Does anyone know what this might be. Here’s a link to a video of it happening in first gear... |
check your transmission mount an see if its busted. because of the weight on it, its not easy to tell if its broken. best to get a floor jack under it for support so you can tell by taking the crossbar lose to let you see if its broke. can just jack it up but risk breaking it if to much pressure is put on it.
