Remote question....
Old Nov 14, 2013 | 08:22 PM
Lebowski's Avatar
Default Remote question....
I have to press the unlock button on the remote of my '97 Z28 and hold it down for at least 10 seconds before the door will unlock. I just replaced the battery so that's not the problem. It's 17 years old so is it just because it's wearing out or do all old remotes do that?
Old Nov 14, 2013 | 08:38 PM
GaryDoug's Avatar
No, you should not have to press for more than a second. This might help: Pry the key fob apart and clean the copper contacts under the buttons. Just use a simple piece of clean cloth, with a very small amount of alcohol if necessary. You don't have to get it real shiny, just remove the black deposits. Try not to move around much or generate any static electricity while you have it open. Worked for me.
Old Nov 15, 2013 | 01:30 PM
Massey's Avatar
^ what he said
Also make sure the rubber pads are clean as well. And if all else fails Dorman is making replacement cases for the fobs that come with new rubber pads.
Massey
Old Nov 15, 2013 | 01:37 PM
frumpy's Avatar
Smile
mine would do this and after cleaning i put a small piece of matchbook cover under the battery and been good ever since
Old Nov 15, 2013 | 10:23 PM
Lebowski's Avatar
I'll give that a try. Thanks....
Old Nov 18, 2013 | 05:05 PM
Lebowski's Avatar
All it needed was a good cleaning. It works instantaneously now. Thanks for the suggestions....
CarolinaCamaro
Oct 16, 2014 01:27 PM
Vet76te
Aug 9, 2010 04:24 PM
mbrg139
May 30, 2010 01:32 AM
sp9o3
Dec 7, 2008 04:00 AM
johnsat
Oct 19, 2007 06:04 PM
