ran goodwhen parked 4yrs ago
Old May 6, 2013 | 03:50 PM
Reggie Thistlewaite's Avatar
Default ran goodwhen parked 4yrs ago
ok so i just got this 94 camaro it ran good when it was parked but its been sitting for 4yrs now i think if i just change out the fuilds i should be fine but want feedback.
Old May 6, 2013 | 07:45 PM
Gas is your biggest problem. If you have bad gas in there the last thing you want to do is force that into the pump and the injectors.
Coolant becomes very acidic over time. That can eat away at seals, gaskets and even Aluminum. You should swap out the coolant, install some water and pressure test it. If everything looks ok add some coolant flush to the water, let it get hot drain it out and install the good stuff.
Change oil before starting. Oil leak tend to start 30 days or so after sitting. The seals will dry up. For he first month you will want to check the oil a lot.
Your plug wires life is based on time. Unless they where new when the car was parked you should swap them out.
Assuming it is a automatic the trans fluid should be swapped.
Saftey first, your going to want to do a stomp test on the brakes. After you start the car push as hard as you can on the brakes. This will test the seal and lines. Lines rust seals dry out. Better to find that out in your drive way then when some moron pulls out in front of you.
Good Luck
Old May 6, 2013 | 08:45 PM
2Z's's Avatar
Have you started the car in the 4 year time period at all? In addition to the above info..... If not, you might pull the spark plugs and using an oil can, squirt a little oil in each cylinder. Turn the engine over a few times with a breaker bar or a large ratchet. this will lubricate the rings and prevent brakage.
I would add some fuel stabilizer or gas dryer to the fuel also before firing it up.
Old May 11, 2013 | 01:12 AM
Ive drain and change all the fluids put new wires and plugs new trans filter and new coolant and air cleaner drain tank and add new gas with lucas gas treatment checked brakes now just waiting for a new vats keys as the old one got lost. Oh and changed the feul filter. any thing else anyone can think of?
Old May 11, 2013 | 09:28 AM
slick's camaro's Avatar
Check tires for dry rot
Old May 12, 2013 | 12:22 PM
I put new tires on it and new rims. I fired it up yesterday and it ran good but i need a new exhuast. it has the stock single pipe but i have a cat back im going to out on it.
Old May 12, 2013 | 12:27 PM
what engine do you have?
Aug 16, 2014 08:32 PM
garrison86
82-92 V6 Tech
11
Jun 21, 2011 02:37 PM
cncfe
Jun 8, 2011 08:01 AM
Spartan66
Feb 5, 2008 05:40 PM
jerakrys
Oct 17, 2007 08:13 PM
