Went for a drive, parked, now car is dead
Old Aug 11, 2014 | 11:56 PM
1969's Avatar
Default Went for a drive, parked, now car is dead
Tried jumping the 2 purple wires at the console (Neutral safety switch)? still nothing. Im thinking the ignition cylinder maybe but how do i check or what is the next thing i should check?
Old Aug 12, 2014 | 06:32 AM
flat tire's Avatar
did you check the battery voltage?, ground wire? voltage to the starter?
Old Aug 12, 2014 | 08:11 AM
With a screwdriver, jump across the start (smaller wire) and battery terminal on the starter, make sure trans is in neutral if it's a manual. If the engine turns over like normal, the battery and alternator are fine.
Then check the start wire at the starter and make sure there's 12 volts there when the key is in the start position.
Anything else electrical related not working? You could have burned a fusible link.
Old Aug 12, 2014 | 04:59 PM
1969's Avatar
Small post on starter is loose even though nuts are tight. I wiggled it and it is now able to start. Is there a way to tighten that post or do i need a new starter?
Old Aug 13, 2014 | 05:50 AM
Everett#2390's Avatar
You can remove the outer nut, terminal lug, and tighten the nut on the post and reassemble.
Old Aug 16, 2014 | 08:32 PM
Scooch's Avatar
Super Scooch
January 2009 ROTM
that same post on my starter has always been loose evenwith the nut tight againt the wires. shouldnt matter. hope you get her to come back to life!
Lakerman62
Nov 11, 2013 03:09 PM
Reggie Thistlewaite
May 12, 2013 12:27 PM
garrison86
82-92 V6 Tech
11
Jun 21, 2011 02:37 PM
Spartan66
Feb 5, 2008 05:40 PM
jerakrys
Oct 17, 2007 08:13 PM
