Power Window Install Problem
Old Jul 24, 2015 | 10:00 PM
rjc362's Avatar
Default Power Window Install Problem
I'm new to the forum and in fact new to owning a Camaro. I have a 96 RS Convertible and I'm currently trying to install a new power window motor (driver side.) The problem I'm having is that after I finish mounting the motor, I try to test it and the window doesn't move. I tested it before mounting and it works fine. I even removed it again and tested it and it still worked. What's odd is that I got it to move once when I tested it after tightening just one of the three screws. Then I tried again after all three screws were in and tightened and nothing. All I hear is a click but nothing moves. It's driving me nuts! Anyone have any suggestions or ideas?
Old Jul 25, 2015 | 04:00 AM
check on the backside and make sure your not screwing into something like the window
Old Jul 25, 2015 | 11:31 AM
rjc362's Avatar
Thanks for the reply! The window is in the up position so not hitting that. Also using pretty small screws but I double checked anyway and doesn't appear to be hitting anything back there.
Old Jul 25, 2015 | 01:41 PM
was just the motor replaced? did you follow any of these instructions https://camaroforums.com/forum/93-02...gulator-64492/
Old Jul 25, 2015 | 02:59 PM
rjc362's Avatar
Yes, only replaced the motor. I referenced various videos and instructions I found online including the second link on the thread you referred to in your reply. I noticed that one of the links on that thread shows how to remove the whole assembly (including the gear) but most of what I read indicated that I don't need to remove all of that just to replace the motor. Which is why I followed the instructions on only replacing the motor. Are there things I can do to also check the gear or other parts of the assembly?
Old Jul 25, 2015 | 03:20 PM
there is a fuse for the windows that will reset automatically i wonder if that is toast.
Old Jul 28, 2015 | 08:39 AM
Tipsy's Avatar
Do you hear the motor running/humming? Maybe gear on motor is not engaged with regulator gear. I had that issue when I replaced mine. Thought I had it lined up and tightened the screws but that was just clamping down on the gear and keeping it from engaging. Had to loosen it and wiggle it around until it turned enough to mesh the gears. difficult working backwards and blindly. Just keep trying.
Old Jul 28, 2015 | 05:59 PM
hooknladder's Avatar
The motor could be in a bind. When I got my car out this spring, the driver window wouldn't work. I removed the motor, cleaned the dust from the brushes out and put the motor back together. It worked fine, but then wouldn't go up one day. I took the door panel off and started removing the three screws that hold the motor in. When I was on the second screw, the motor jumped like it was in a bid. I tried the switch and the window worked fine. It is a replacement motor to begin with, and the holes don't exactly line up. I left one of the screws out and it has been working fine. This motor is really tired and will be replaced soon.
Dana
Jul 16, 2014 07:31 PM
68ssmaro
Mar 2, 2010 10:56 PM
Tar Heel
Aug 21, 2009 03:55 PM
joey
Aug 15, 2007 06:19 PM
