.sqeak noise from under dash from AC
Old Jul 28, 2015 | 04:25 PM
95 camaro 406's Avatar
Default .sqeak noise from under dash from AC
?got a noice from under dash ,comes from ac on an off,i have had other cars do this before I just want to make sure its .not a sign of trouble ,I am bringing it in for inspection soon an going to have the compression test done to,i guess if I can get the problem of the head gaskets on these before any damage is done ,,the ac. has worked great its got a new .compres.er,the evap get a lot of condisation built up on it? don't they have insulater for those other then noti.ceing it was beach car an has bit more .rust under the hood then my 95 I have spartyed a lot of wax on the rusted areas under the res tank there is no. rust build up ? generaly what does it cost to replace the head .before it goes be ,thank you
Old Jul 28, 2015 | 06:39 PM
passenger side? the door in the core unit changes position when you turn ac on
Old Jul 28, 2015 | 07:23 PM
an does it when you shut it off I guess that can go on for long time ,thanks craby
B_Dubya
Mar 27, 2015 02:10 PM
augie1209
Apr 15, 2012 07:45 AM
spencer215
82-92 V8 Tech
Mar 15, 2009 06:33 PM
msp54
Apr 25, 2008 07:22 PM
MartynCZV6
Apr 10, 2006 05:11 AM
