Passenger Widow will Roll up, Not down.
I have a 95 Z28 and my passenger window will roll up but ot down.
I have replaced the motor i the window, the passenger window switch, and the Drivers master widow switch and widow still does the same thig.
Any light on the subject?
Thanks!
Josh
Thanks!
Josh
You could have a cracked/fatigued wire (there's one for up and one for down control). Open the door. At the hinge pillar, grab the rubber boot with the wires inside it and wiggle it back and forth while trying the switch at the same time. If the window motor works, you'll need to go fishing for the bad wire. If that does nothing, have someone help you by wiggling the wiring boot on the drivers door (power supply goes from drivers to passenger side door) Believe it or else, this has worked for me on more than one car.
