Passenger Axle Seal keeps failing
Old Feb 8, 2011 | 02:37 PM
libertyforall1776's Avatar
Post Passenger Axle Seal keeps failing
My passenger side Axle Seal keeps failing on my RS -- this is the 3rd time getting it fixed -- anyone else know what the deal is on this repeat failure point which leaks fluid?
This time Chevrolet replaced the Axle Shaft, Bearing and Seal (extended warranty) -- they claim the right rear axle was damaged, or they just like to soak the ext. warranty company... Maybe they found the root cause -- finally?!
Old Feb 8, 2011 | 03:06 PM
Massey's Avatar
The only thing I have ever found to cause repeated failures like you are having is a bent or damaged axle shaft. I would say GM is going about getting it fixed the right way for you.
Massey
Old Feb 8, 2011 | 03:53 PM
You could have had a wear ridge on the old axle. A new seal holding well, hitting in the same place, will only last so long (or short) if that was the case.
DSteinyZ28
Apr 23, 2012 10:19 AM
maudyZ28
Mar 12, 2010 07:08 PM
nnewquist
Feb 22, 2010 03:15 PM
oZcar
Jun 28, 2007 12:57 PM
BlitzKrieg
Apr 8, 2007 12:52 AM
