Oil Pan Gasket Replacement
Old Feb 8, 2011 | 02:46 PM
husker_camaro95's Avatar
Default Oil Pan Gasket Replacement
So... I have a 95 3.8L and I believe the gasket on the oil pan is leaking... (atleast I hope it is that and not the rear main seal). I hear this job is a pain.... has anyone done this before?
Old Feb 8, 2011 | 03:04 PM
Massey's Avatar
It is a pain since the K-member is in the way. You need to unbolt the engine from the K-member lift the engine a little and lower the K-member enough to clear the oil pan. The gasket is a large one piece gizmo that has the splash guard or baffle built into it. Simple to install but a pain to get to.
Massey
Old Feb 8, 2011 | 04:16 PM
MelloYello's Avatar
yeah support the engine from the top and disconnect engine mounts and lower the goldmember, i mean, k-member.. shouldntreally be to much of a job
if it was your rear main seal the bottom bell housing half would be super sludgy, and the front of the pan almost dry.. if its a pain gasket the area thats leaking should be the muddiest.. and possibly a dry spot were it dont leak none
shai one
Jan 16, 2012 10:02 PM
Sungeun
Jul 7, 2010 06:29 PM
ryden
Mar 14, 2010 05:30 PM
dksob81
Nov 1, 2008 07:48 PM
jdubs1813
Jul 19, 2007 10:41 PM
