Overheating. I searched 1st
Old Jul 23, 2008 | 07:59 PM
kaoss_11's Avatar
Default Overheating. I searched 1st
95 camaro z28
New thermostat
new optispark
new water pump
I tested my fans and they both turn on when I put a paper clip in the thing under the dash. I vented the system by unsrewing the nipple in the radiator hose and the car overheats. Also the fans wont turn on by themselves and I replaced the old fan relays with brand new ones. Any ideas?
Old Jul 23, 2008 | 08:42 PM
Default RE: Overheating. I searched 1st
If the fans fail to go on by themselves, check the engine temp sensor (not the temp gage sender), and wiring & connectors from sender to PCM. Then from PCM to fan relays (there a 3 of them) Low speed should go on @ 220 & high speed at over 225. Fans should run anytime the AC is on. Also make sure the air dam under the radiator is in place.
hoursetraitor
Nov 18, 2010 10:11 AM
Swimmerboy2112
Aug 29, 2010 08:09 PM
bsmith01
May 13, 2008 04:40 PM
kaoss_11
Apr 15, 2008 12:27 AM
420GOAT
May 18, 2007 10:34 AM
