Replaced opti now wont start
Old Jul 20, 2008 | 09:35 PM
rwing7486's Avatar
Default Replaced opti now wont start
just replaced the opti in my 94z28 myself and reasemebled everything and now the car wont turn over. it cranks but does not turn over, and i can smell gas fumes under the hood so i know its getting fuel. When i replaced the opti it took me a bit but i found the key groove and it slid right in without being forced and it was tight against the timing chain cover. Anyone know what i did wrong? any advice would be nice cause i am really bumed out after all that work that it still doesnt work. Also before i removed the old opti the car would start but not rn right and i got the codes for the hi res and low res failure.
Old Jul 21, 2008 | 12:21 PM
rwing7486's Avatar
Default RE: Replaced opti now wont start
cmon someone has to hae some input here
Old Jul 21, 2008 | 01:34 PM
viciouZ's Avatar
Did you run your wires correctly?
Old Jul 21, 2008 | 09:35 PM
rwing7486's Avatar
ya i doubled checked the the wires. i replaced the opti cause i got codes 16, 36, and 42. is there something else that could be causing this problem??
Old Jul 21, 2008 | 10:25 PM
importmd's Avatar
cranking and turning over are the same thing
Old Jul 21, 2008 | 10:26 PM
importmd's Avatar
arent you the guy that bought a cheap opti off ebay after i told you not to?
Old Jul 21, 2008 | 10:27 PM
importmd's Avatar
check for spark coming out of the coil and out of the opti.
Old Jul 21, 2008 | 10:39 PM
rwing7486's Avatar
no i got mine from summit
Old Jul 21, 2008 | 11:05 PM
importmd's Avatar
so...do you have spark?
Old Jul 22, 2008 | 12:33 PM
rwing7486's Avatar
ya i have spark so im thinking its not the opti
