Overheating ?
Old Apr 23, 2012 | 09:07 PM
sorry, if you have ac then you will most likely have separate fan curcuits and relays. if you have two fan relays in the under hood fuse box then you have the option. the production code is c60. my current 93 both come on and the old one i dont know. anyways look over the links i gave.
Old Apr 23, 2012 | 09:10 PM
MKCoconuts's Avatar
I'd still recommend doing a full flush and fill. Just be careful and stuff rags near the opti, cause it can get messy and you don't want your (knock on wood) opti to go out because of it. If your just sitting and idling and it's getting that high, you're fine. If you were doing highway cruising, I'd be scared.
Old Apr 23, 2012 | 09:12 PM
Paul86iroc's Avatar
I have a 86 iroc 305 carbed it had a constant over heating problem. So I put a big block flex fan now it runs at 100 I have a 195 therm and it sits at 160 on a hot day. The fan is a beast. Is this bad?
southw2
67-69 V8 Tech
Jun 12, 2011 10:02 AM
greenmachine96
Mar 18, 2011 12:29 PM
boxeranders
Jun 25, 2009 01:05 AM
g.pelka
Jan 31, 2008 07:00 PM
ChevCam87
82-92 V8 Tech
Jan 11, 2008 11:46 AM
