Overheating ?
Old Apr 23, 2012 | 12:09 PM
phoenix901223's Avatar
Default Overheating ?
Just bought a 1993 M6 Z28 and it seems to be running a little hot. Heat takes a long time to come on and when it does its lukewarm at best. Temp will climb to right under red line, than one fan will come one and the temp will lower a little. this happens while driving and idle Once it starts getting hot, coolant light comes on. Is this too hot? I think im going to flush everything, does anyone know of a good writeup
Old Apr 23, 2012 | 12:11 PM
Coolant level in resavour is at correct level btw. And how does that oil pressure look for idle?
Old Apr 23, 2012 | 12:30 PM
Chaotic94's Avatar
September 2011 ROTM
That oil pressure looks okay to me. My car idles around 30psi and jumps up as my rmp's rise. You may need to bleed your coolant system. I believe your car has a bleeder valve somewhere. One of the z28 owners will chime in and let you know pretty quick I'm sure.
Old Apr 23, 2012 | 12:43 PM
I opened both bleeder valves and just coolant came out.
Old Apr 23, 2012 | 12:51 PM
That mark where the needle is, is just a tad over 200 (almost 210), you're fine.
For reference, the center mark on the gauge is 180 degrees (260+100=360/2 = 180). And each notch is in increments of 20 degrees.
Old Apr 23, 2012 | 12:58 PM
Okay cool. I was going to do a full flush but I think i will start with just the heater core. only one of the hoses is getting hot, im suspecting a blockage
Old Apr 23, 2012 | 01:24 PM
Chaotic94's Avatar
September 2011 ROTM
^definitely have a blockage.
Old Apr 23, 2012 | 01:47 PM
Catmaigne's Avatar
For reference, the low speed fan kicks on at 226 and the high speed at 235. The car should yoyo between 210 and 230 when idling + stationary.
Old Apr 23, 2012 | 08:39 PM
93 all fans come on at once, on if ac is on and on at 230 i think. look at 12 through 16 here 4th Gen LT1 F-Body Tech Aids have mine tuned for a 180 setup, with tune i think the fans come on at 200. unless its 80 or 90 degrees out both my 93s are/where between the second mark and the center mark even before the tune. if its really hot then it has gotten to the third mark. i got really nervous. test your temp sensors, temp gage sensor i on the driver side head by the number one spark plug, temp sensor is on the front of the water pump. test ohms at number 20 on the same site i linked.
Old Apr 23, 2012 | 08:49 PM
Only one come on and.its the one you can't really see I only here it
I the two u can see from under do not turn on
