Okay so I bought it
Old Jul 23, 2012 | 12:02 AM
  #21
H2C's Avatar
H2C
Originally Posted by craby
yes but its not good to run the motor outa gas, better to cut the injectors.
I want to be able to cut all the power on and be ready to start without tripping the fuel pump.
Old Jul 23, 2012 | 12:04 AM
  #22
Wouldn't that essentially give the same result? If he should kill power to the pump, the injectors quit squirting due to lack of pressure and the engine kills. He wouldn't be evacuating the fuel system by doing that.
Old Jul 23, 2012 | 12:09 AM
  #23
H2C's Avatar
H2C
I would never purposefully run my engine dry, isn't that what ruins injectors?
I was always told that
Old Jul 23, 2012 | 12:23 AM
  #24
It takes very high fuel pressure (from the fuel pump) to push gas through the needle fine orifices of a fuel injector. Kill the pump, the injectors quit squirting, and the engine quits. How does that run the engine dry? Frankly though, I don't see the purpose of what you're trying to achieve. Is it for added security, or maybe to make yourself feel like a jet pilot?
Old Jul 23, 2012 | 01:01 AM
  #25
H2C's Avatar
H2C
Wrc pilot actually
I would kill to step in Sebastian Loebs shoes for a day
But nah I just like to do small things while I'm paying it off, then its time for some BOOOOOOOOOOST
Old Jul 26, 2012 | 02:58 PM
  #26
H2C's Avatar
H2C
LEL it came today
Ferrari Keychain too
Old Jul 26, 2012 | 08:09 PM
  #27
Correct, starve a engine for fuel to shut it down then just pull a plug. It will have a white haze to it and and it will spike the cylinder temps right before it shuts down, that is a real bad time to spike a temp. The problem is it takes a second or two for the pressure to drop off completely because the pump is spinning so fast. Even at 1200 RPMs each cylinder will fire 10 times per second. The last thing any motors needs is 20 lean fires right before shut down. It can be very hard on the head gaskets.
Old Jul 29, 2012 | 01:00 PM
  #28
Greg08's Avatar
Sometimes u just gotta let it run dry
Old Jul 31, 2012 | 09:25 AM
  #29
H2C's Avatar
H2C
@Greg
what?
Mornieaux
82-92 V8 Tech
May 7, 2009 05:46 AM
locotrician
Apr 17, 2009 11:21 AM
1988camarov6
82-92 V6 Tech
Aug 19, 2008 11:55 AM
evilhaserrors
Jul 12, 2007 10:50 AM
