Ok guys... Project Camaro will about to be done
Old Apr 28, 2009 | 05:20 PM
SixShooterCamaro's Avatar
Default Ok guys... Project Camaro will about to be done
Just have a question for ya...
Ok so a buddy of mine has a 1997 Firehawk which has an LT4 in it with around 385 horses. He is swapping that out with a 6.2 corvette engine his friend is giving him. Now he is selling me the motor/tranny/suspension/rear-end/ECM/wire-harness etc.. for 5 grand which is a steal especially for the motor only having 27,000 miles on it.
Here is the kicker, I have 1995 3.4L V6 camaro.. Although his friend owns a shop and basically will do the swap, is there anything I should know before doing this or any complications I may run into, or am i good to go?
Old Apr 28, 2009 | 05:25 PM
02StanGT's Avatar
New (bigger) radiator, new fans, fuel pump, exhaust will be a bit different, and that is all that I can think of right now. Wait... You may need a new gauge cluster. Keep in mind that you are going from OBD-I to a OBD-II system.
Old Apr 28, 2009 | 06:03 PM
I already have a V8 Radiator out of a 97 z28... My friend isnt giving me the fans but oh well I can buy them and gauge cluster isnt too bad of an item to get.... so basically fuel pump and exhaust... which my boy is giving me his exhaust, I already have Z28 rims which i probably wont use...
Is it true that I have to change the VIN when I go do emissions?
Old Apr 28, 2009 | 06:14 PM
YoungDriver's Avatar
Won't he need a better tranny and driveshaft?
Old Apr 28, 2009 | 07:53 PM
Thats all part of the 5 grand... he is giving me his driveshaft and tranny.. it also has a shift kit and a 1700 stall converter, I asked him if the driveshaft would fit because im sure its a different wheelbase and he said he would throw in his suspension with it so everything fits
Old Apr 28, 2009 | 08:51 PM
Tonylig928's Avatar
sounds like a good deal!
your gonna need a radiator(which you said you had),fans, fuel pump, prob. the gauge stuff, it's gonna be some project but just double check the work when you do it ! make sure everything is where it should be. and it should be fine.
Old Apr 28, 2009 | 11:07 PM
Yeah I figured that much... I just cant wait til I get started, im going to his place tomorrow to sit down and sketch out everything were gonna do... everything from rims, paint, engine mods etc...
But someone told me if I do a swap then ill have problems taking it to emissions because the VIN will read for a 3.4L Camaro but I didnt know emission places read the VIN or put it in the computer... is there any truth behind that?
kpaykov
Feb 17, 2011 11:07 AM
DAMIENPL7
Apr 12, 2009 12:56 PM
camarorsyupp
82-92 V8 Tech
Jan 30, 2007 12:34 PM
Valek
Sep 21, 2005 11:47 PM
