Not crank, everything dead
Old Apr 21, 2018 | 09:21 AM
Terry's Avatar
Default Not crank, everything dead
94 Camaro Z28, Auto. 80,000 miles. Good battery 12.4 volts. Will not start, will click when turning ign key then everything goes out, no dash lights no interior lights. Wait 1 min and nothing, no click. Wait 5 minutes and get interior lights and dash lights but will get the click but then nothing works all lights go out again.
Thanks for help.
Old Apr 21, 2018 | 11:01 AM
Y2K's Avatar
Y2K
Sounds like a bad battery connection, check your terminals for crud, bet it starts up with a jump. It should be about 14 volts running if the alternator is working right. Pretty common problem,I've seen many people buy a new battery when all they needed was a good terminal cleaning or possibly new cables. Could be other things too like a bad starter, first thing I'd do is put jumpers to it and see if it starts if cleaning up and making sure the cables are clean and tight do not resolve the problem.
Old Apr 21, 2018 | 01:31 PM
yep, clean cable ends and battery terminals. i have had to scrape them with sharp knife before to get a hard coating of stuff off. carbon i think.
Old Apr 21, 2018 | 03:40 PM
Y2K's Avatar
Y2K
Make sure the cable on the starter end is tight too, I've seen just a loose positive on the starter do this.
Baking soda and water mixed to a thick cream consistency applied to the battery and cable terminals for a few minutes and rinsed off with water does wonders, then a good scrubbing with a wire brush till they shine.
Old Apr 21, 2018 | 11:06 PM
lose wire at the starter should not make everything go off.
Old Apr 22, 2018 | 01:12 PM
Terry's Avatar
Default Thanks
Thanks for the ideas, I cleaned and ran sandpaper over all the electrical ends including the electrical wires and contacts on the inner fender. Then I removed the cut off switch from the neg battery side and everything works. I think the battery cut off switch was bad. Again thanks for your help, I am glad it was not a relay or sensor.
00camaroloyd
LS Series Tech
Aug 3, 2017 05:44 PM
xXOfNiRXx
Nov 21, 2011 08:40 PM
SixShooterCamaro
Dec 5, 2009 10:58 PM
gotalcoholmanup
May 16, 2007 12:59 PM
