LT1/LT4 Tech 1993-1997
List of everything I have and everything I will have come two months...
Old Nov 26, 2009 | 05:03 PM
SixShooterCamaro's Avatar
Default List of everything I have and everything I will have come two months...
Car: 1996 Camaro z28 4L60e
Current Mods:
K&N CAI
Ebay Headers (shorties)
Spun Cats w/ Dynamax bullit race muffler dumped at axle
Eibach Springs
Bilstein shocks
upper and lower control arms w/ strut bar
Future Mods:
383 rebuild with Scat rotating assembly w/ forged crank and pistons (I decided on 383)
Pro Charger setup
LE2 Heads work with matching Cam (284 to 292)?
Pacesetter LT Headers with x-pipe kit with dual tips coming out of the body before the tires
Baer front brakes 2 piston
2500 stall
Ford 9 inch w/ 373 gears
Roll cage and sub frame connecting rod
MSD Ignition
58 mm throttle body w/ 40 lbs injectors
Projected HP goal: 550 RWHP
Old Nov 26, 2009 | 05:14 PM
dont forget 1.6 roller rockers. should go with 7/16 rocker studs.
Old Nov 26, 2009 | 05:40 PM
I knew I was forgetting something... Sorry I was in a hurry to eat some turkey lol So based on that list you think ill be good to go? im also gonna have the shop do a complete engine bay delete for a nice looking engine bay
I may also need to get a tranny heavy duty kit
Old Nov 26, 2009 | 07:15 PM
sounds good to me, give lloyd a call and see what hes got to say. im sure he will have some input.
Old Nov 27, 2009 | 08:32 AM
whammer3024's Avatar
ROTM Winner
i think that stall is going to be too small for what you're looking for...but that could just be me.
and i'd personally be looking at a different rotating assembly. for something like that, i'd be looking into compstar if it were me
Old Nov 27, 2009 | 07:59 PM
yeah maybe youre right on the stall... will see... what you think 2800?
why compstar over scat?
Old Nov 28, 2009 | 07:05 AM
ROTM Winner
compstar is known to be top of the line...look at advanced inductions...all they sell is compstar crankshafts, then i'd use lunati rods and diamond pistons, especially if i was going to be running boost...you don't want to skimp on parts if you're going to be going FI. just asking for trouble.
and as far as torque converter...read my sig...i'm cammed and run a 3600 stall...just something to consider
Old Dec 4, 2009 | 06:13 PM
Yo why the heck is compstar so expensive for the rotating assembly... its like 1800 bucks
Old Dec 5, 2009 | 10:58 PM
robmnrd's Avatar
A procharged 383 is gonna have one of the fattest torque curves you can imagine, unless you go with a monstrous cam that isn't specced for the blower. With this in consideration, I'd say a 2500 stall will be sufficient, though I wouldn't turn away something in the 2800-3000 area if you get a good deal.
Edit: In fact, (and this one will probably pull a bit of controversy on this site :P) I'd suggest opting for a 3.55 rear gear. With a build like this you don't need to worry about stalling the car into your torque band, just worry about making sure you effectively use the power band.
bthumber
Jul 4, 2010 12:05 PM
heartbeat_jr
Apr 1, 2010 12:24 PM
TwistedEdge
Oct 2, 2008 04:27 PM
