LT-1 will not crank!!!
Old May 14, 2007 | 11:20 PM
gotalcoholmanup's Avatar
Default LT-1 will not crank!!!
i went out to my car tonight and it wouldnt start. The starter sounds like its working and the batery gauge is at 12 volts. I just replaced the plugs and wires about 15,000 miles ago. about 5,000 miles ago i got the fuel pump replaced. I checked all of the fuses and they are all fine.... any ideas???
Old May 15, 2007 | 03:11 AM
Saint_Ali's Avatar
Default RE: LT-1 will not crank!!!
sounds like it could be the optispark
Old May 15, 2007 | 04:49 PM
usarmyrangrs's Avatar
Will not crank, or will not start?
Old May 16, 2007 | 12:59 PM
redlt1's Avatar
Ifthe car actually rotates and won't start then you need to verify the f/pump runs, or checkfor spark at the ignition coil with a spark tester. If the car does not rotate at all, your stater solenoid connections could be loose or the starter may be defective.
tbl76camaro
Jan 21, 2011 06:10 PM
9t4Z28
Apr 15, 2009 08:26 PM
Rfalker1
Dec 25, 2008 08:18 PM
camarohelp
Jul 17, 2008 09:52 PM
bobbeam327
Feb 12, 2006 10:29 PM
