no strt prob.....HELP!!!
are you getting power to the fuse box? better get the volt meter out and start checking around. could be a ground or hot wire problem. you have a power and ground junction boxes on the passenger side fender well, be a good place to start. did the air bag go off?
Problem Solved
Well yall we finally figured out what was wrong with my car...it was a BLOWN fuse,gauges fuse!!!! All that time,wow. We had checked the fuses under the hood but forgot about the ones inside the car. Anyways I just dropped her off at the paintshop. Ill post pics as soon as I get her out. Yayyy!!!!!!!
