New engine
Old Jan 21, 2009 | 03:56 PM
Ace-Willie's Avatar
Default New engine
wats the best way to break in a engine? i read some where is to run it hard its a v6 3.8 wat do u guys think?
Old Jan 21, 2009 | 10:46 PM
kaoss_11's Avatar
drive it like a sane person and your done
Old Jan 22, 2009 | 01:21 AM
95slvrZ28's Avatar
Honestly with newer engines that have a full roller assembly you don't need to worry about break in like you used to. Don't drive the motor too hard, but make sure the first time you drive it you get the motor fully warmed up so everything gets it's correct amount of lubrication and the rings get seated. Other than that, you should be good to go.
Old Jan 23, 2009 | 07:29 AM
torque_is_good's Avatar
I'd change the oil at 1k miles.........pssstttt, don't use a Fram filter or you'll be castrated by some of the forum members............
Old Jan 23, 2009 | 12:53 PM
z28rob18's Avatar
wats wrong with fram?
Old Jan 23, 2009 | 11:28 PM
95slvrZ28's Avatar
Regular Fram filters are crap, don't use them. If you use the Tough Guard filters they have a different filter element in them and do a much better job. I personally use the Tough Guard, they do a good job for the price. I can't remember where, but somewhere I came across an article that compared the different filters etc. and they analyzed the different elements and that sort of thing.
Old Jan 25, 2009 | 07:32 PM
97 lt4 z28's Avatar
im definetly not a fram "fan" either, i read in another forum that the fram was made of cardboard and if u get moisture in your oil it tends to expand. it also said they had to dish out alot of money to consumers to fix or replace there engines. i personally wouldnt use one. thats just my opinion. u can get a k/n from jegs for 10.99 delivered to ur door, and they have a 1inch nut welded on the bottom of the filter for easy removal. thats what i use
onefastls1
Jan 2, 2013 01:45 PM
martynlutherking
May 25, 2010 11:12 PM
Chevykicksbut
Oct 28, 2009 07:14 AM
drabina
Jul 25, 2008 08:56 PM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
