Need some help with linkage adjustment
Old Nov 28, 2014 | 10:22 AM
blakeyon2asd's Avatar
Default Need some help with linkage adjustment
Hi everyone I've got a 95 3.4 automatic that I don't know a whole lot about. I just bought the car and got a great deal on it. The only thing I've noticed was that there is play in the gear shiftier, I'll put it in reverse and it'll go into neutral but if I kind of wiggle it, it'll go in and drive fine. I don't exactly know but I'm thinking it is the shiftier cable or linkage adjustment on it that needs to be fixed. The car drives great and shifts good on the road, but when I get on the highway the check engine light comes on I don't know if the two are related but the car doesn't do anything out of the ordinary other than the problem with the shiftier. Does anyone know what it could be? I've had absolutely no problems with the car as far as the engine and motor so I was thinking maybe the shiftier not being adjusted right could cause the check engine light. Any help would be greatly appreciated.
Old Nov 28, 2014 | 08:15 PM
see if this helps
Adjust A4 Trans Linkage
Old Nov 29, 2014 | 08:52 AM
Okay will do!
n269nando
Aug 19, 2010 06:25 PM
77nomad
Dec 19, 2009 06:26 PM
derekstl
Dec 1, 2009 04:33 PM
uestraven
Nov 11, 2009 11:46 AM
srmrvette
Jun 13, 2007 10:47 PM
