clutch linkage
Old Dec 17, 2009 | 09:06 AM
Default clutch linkage
Can anyone tell me the difference between 70-71 and 72-81 clutch pedal assemblies. These two auctions are on ebay and if i can save a buck I will. http://cgi.ebay.com/ebaymotors/1970-...item5ad1006bda
http://cgi.ebay.com/ebaymotors/72-81...item33572c1f9f
I got the pedals out of the j-yard about ten years ago and have absolutely no recollection if it was an early or late 2nd gen.
Thanks-Damon
Old Dec 17, 2009 | 07:37 PM
Well Until I saw the two ads I didn't know there was a difference? Interesting!
Old Dec 17, 2009 | 08:55 PM
Well poop. I was kind of hoping you were going to chime in with the answer. Anyone? Anyone?
Old Dec 19, 2009 | 10:42 AM
Well i talked with a guy at Tamraz, the company offering the linkage. The tech guy wasn't in today but the dude I did talk to said that the floors were wider on the 70 and 71's. Anyone know about this?
Old Dec 19, 2009 | 10:54 AM
Doesn't sound right, as all the replacement floor pans are listed as 70-74, or 75-81. I thought the change in floor pans was in 1975 because of this.
Old Dec 19, 2009 | 11:30 AM
What you're showing is the clutch linkage, not the pedal assembly. For what it's worth, many moons ago I converted my first 1969 Camaro over to a manual trans. I bought a trans, the whole pedal assembly (clutch and brake), the linkage and all other related stuff from one person. The entire assembly was out of a 70 Camaro, but everything fit and worked fine (except for I had to get the right frame bracket). If there's a difference in components as of 72, I don't know what it is. Looking at applications in the Classic Industries catalog, the bellcrank and the frame bracket are the same for 1970-81 models. Maybe the rod lengths are different between the two, if it attaches to the clutch pedal in a different position?
EDIT: looking at the pictures of the two linkage assemblies, unless it's a positioning difference in the photo, the long rod on the 70-71 has a slight dog-leg, where I don't see one on the 72-81.
Old Dec 19, 2009 | 06:26 PM
I see what your talking about. I asked the question because they offer different pedal assemblies too. The car I got mine out of was stripped down to the shell and I can't remember the year. Good call though. I ordered the linkage for my 78. I'm pretty sure everything will fit. If not Tamraz has a 30 day warrenty. I though all the floor pans were the same exept for the 75 and later having a hump for a converter.
Eric Leidich
Aug 19, 2012 07:24 AM
uestraven
Nov 11, 2009 11:46 AM
irocktheIROC
Mar 29, 2009 11:50 AM
z28cam15
Oct 8, 2007 10:26 PM
83Prostreeter
Oct 9, 2006 07:35 PM
