Need help removing tie rod end
just spins on the inside tie rod ends. if you look at the link you can see the inside ones are in line so they rarely go out.
After you get finished roasting and baking the end of the tie rod, the metal will have lost its temper and the entire tie rod assembly should be replaced, if nothing else, for safety sake. You could probably save yourself a lot of aggravation and change both the inner and outer sections and trash the bad assembly. You may need to borrow a special tool to disconnect the inner section from the steering rack
