Need help removing tie rod end
Old Apr 17, 2012 | 05:29 PM
If it's a conventional thread, you want to turn the nut counter-clockwise (lefty loosey), to back it away from the tie rod end.
Old Apr 17, 2012 | 06:39 PM
borjawil's Avatar
got it off! left the mapp gas torch on it for a good 10 mins or so. the jam nut never came loose but the end did though. Also for future reference the threads were not reversed.
Old Apr 17, 2012 | 09:21 PM
just spins on the inside tie rod ends. if you look at the link you can see the inside ones are in line so they rarely go out.
Old Apr 18, 2012 | 06:52 PM
After you get finished roasting and baking the end of the tie rod, the metal will have lost its temper and the entire tie rod assembly should be replaced, if nothing else, for safety sake. You could probably save yourself a lot of aggravation and change both the inner and outer sections and trash the bad assembly. You may need to borrow a special tool to disconnect the inner section from the steering rack
allport35
Jul 8, 2013 05:52 PM
s_m_a38@yahoo.com
Mar 26, 2011 10:07 AM
94.V6.VROOM
Feb 8, 2010 08:13 PM
94z
Jun 26, 2008 01:33 PM
