The mystery of the missing MAF
Old Aug 14, 2014 | 06:59 AM
GaryDoug's Avatar
A missing AIR pump probably wouldn't cause those failures, besides, have you confirmed that anything is actually missing? It might just be unplugged. It would be more like a failure of a visual check for missing components done by the inspector. Your failures are probably due to other defects. I am sure other folks here can help with that better than I can.
Old Aug 14, 2014 | 08:20 AM
rock auto has the pump, 140 to 155 bucks depending on brand. acdelco part #215345 standard motor part # AIP11 check fuse for the pump.
Old Aug 14, 2014 | 12:07 PM
As mentioned, the AIR pump only runs upon initial start up, it's to help warm up the cat converter faster. Once the engine is warmed up a little, the pump isn't running and has no effect on emissions. You might fail a visual inspection if they look under the hood, and know what the heck they're looking at, otherwise I wouldn't waste my money on a new pump. Here by me, they don't even pop the hood when doing the emissions test.
Old Aug 14, 2014 | 01:42 PM
JackFrost's Avatar
well thanks for the tip that'll save me money on it! I should take it back through emissions since it's had a tune up and see if that makes a difference.. I'm its new owner so im not completely sure what to expect from it yet.
omr
Oct 25, 2014 07:02 AM
Michael Smedley
May 27, 2011 07:43 PM
Racerx11
Jul 24, 2009 05:49 PM
Noxzima
Nov 26, 2008 04:52 PM
thirdgencammyman000
82-92 V8 Tech
Apr 29, 2008 01:33 PM
