LT1 to LS1 PCM Swap
Ok will do greenarrow. You can send those links to me when you get a chance so I can take a look. I graduate college in 2 weeks so I will be working full time and have some money coming my way so I might consider doing it soon.
From what I've researched, if you can get the LS1 PCM and harness for cheap, then it would be worth it. But I wouldn't do it for a DD, it would make a DD more reliable but I don't see it being worth it for a non-project car. But it also depends on the timing cover, because I think you need a 96-97 LT1 timing cover or you have to weld the 94-95 opti hole up. There's a lot of things to consider, but I think if you can get the main componets on the cheap then yes.
9434V6
09-08-2011 11:51 AM
