LS1 Camaro Vibrations
Old 07-15-2013, 06:31 PM
Hopefully you put a reference mark on the flexplate and t.c. as already mentioned, so you know where you were. Once in a while things can be just a hair off balance, and rotating the t.c. one bolt mount location on the flexplate can sometimes smooth it out. It's worth a shot.
  #22
Old 07-15-2013, 06:55 PM
libertyforall1776's Avatar
So try a rubber/OEM trans mount -- pretty easy to do...
  #23
Old 07-15-2013, 06:59 PM
That would likely help to mask the symptom, but not cure the cause.
  #24
Old 07-17-2013, 07:58 PM
allmiller4u's Avatar
I rotated the T.C. one bolt and it did reduce the Vibration by quite a bit! Don't get me wrong there is still a noticable vibration at verying RPM's but not as bad as before. Now the car wont rattle the change around in the cup holder as bad. Anyways I am just going to drive it out for now and see what happens?
93camarolt1
02-23-2014 06:50 PM
brownstone101
01-15-2011 08:45 PM
CMan84
82-92 V8 Tech
03-21-2010 11:11 PM
vega1485
82-92 V8 Tech
01-12-2008 09:23 AM
flyin68
04-02-2005 01:57 PM
Quick Reply: LS1 Camaro Vibrations
