Key Won't Start Car
Old Feb 28, 2011 | 11:15 AM
husker_camaro95's Avatar
Default Key Won't Start Car
So... a long while ago... i was trying to start my camaro and the key appeared to be jammed. it would not turn... it would go to accesory, but no further. I turned it harder.... then the bad happened... clunk... the key will turn, but when I turn it all the way, nothing happens. so... to resolve this issue, i just used my remote start for a while, then installed a push button start. those options still work fine, but I was thinking about trying to figure out what might be wrong. I took the steering wheel off and changed the tumbler a while back... didnt do anything (accept make my security system angry, had to wire in the resistor to get it to shut up, stupid VATS). Anyways.... I have a new ignition switch... but getting to it down in the steering column looks horrible. As far as I could tell, when I had the steering column apart, everything appeared to be working just fine mechanically. as of now... I just use the push button start and leave the key in the on position to unlock the steering wheel. I was just wondering if anyone has any idea what might be wrong.... It acts like its not sending any signal to the starter. no clicking, no nothing. any ideas?
Old Feb 28, 2011 | 11:33 AM
check the linkage and switch. heres every thing i have
Size:  49.3 KBName:  PB080020.jpg
Size:  52.1 KBName:  PB080018.jpg
Size:  68.7 KBName:  PB080017.jpg
Size:  56.0 KBName:  PB080016.jpg
Size:  54.5 KBName:  PB080015.jpg
Size:  44.2 KBName:  PB080014.jpg
Size:  59.2 KBName:  PB080013.jpg
Size:  52.1 KBName:  PB080012.jpg
Size:  55.0 KBName:  PB080011.jpg
Size:  60.8 KBName:  PB080010.jpg
Size:  57.6 KBName:  PB080009.jpg
Size:  56.1 KBName:  PB080008.jpg
Size:  60.9 KBName:  PB080007.jpg
Size:  73.3 KBName:  PB070008.jpg
Old Feb 28, 2011 | 11:35 AM
one more
Lakatrae
Mar 29, 2014 10:59 AM
rdb357
Mar 30, 2008 08:25 AM
JTyler
Aug 31, 2007 10:21 PM
coco
Aug 13, 2007 10:33 AM
