ignition switch problem
![](http://i43.tinypic.com/sze804.jpg)
my 95 camaro recently decided not to switch over and start so i took apart the dash and everything got to the switch and now i cannot pull the black cord/wire out of the bottom of the switch. i can get it to come out a little but not all the way. anybody have any help here? the cord is stuck on the black part in the picture above.
okay my initial problem was the car wouldnt start when i turned the key but it would turn on the vents, and radio, but not the dash, and it wouldnt try to turn the car over at all just made a click when i went to start the car. maybe its possible the ignition lock is the problem and not the switch? this is the only conclusion i can come to because this wire is not comming out. i tried putting the key in every position, without the key.
