ignition switch rod
Old Jul 12, 2014 | 01:00 PM
JohnnyCars's Avatar
Default ignition switch rod
I'm replacing the ignition switch on the steering column.
When I try to install the new switch the actuator rod seems to be facing the wrong direction. The bent end of the rod faces up, and the slot it goes into is on the side of the switch.
The switch matches to old switch, so I think it's the right one.
How do I get this rod into the side of the switch? I don't think I should have to bend the rod. I should have paid more attention when taking the old switch out!
Old Jul 23, 2014 | 01:27 PM
6t9sscamaro's Avatar
A little slow to respond to your question but if you have a Chassis Service Manual it shows the column diagram on page 9-15 for a non-tilt column. If you don''t have one I highly recommend getting one. I'm sure there's a pic posted somewhere you can access. If not, send me a pm and I'll send one to you.
Delray Gugle
Apr 7, 2014 07:04 PM
tampatony
Feb 20, 2014 01:59 PM
evilmnky45
Jul 31, 2011 05:24 PM
qqqa
Jul 28, 2008 12:27 PM
w0211644
Mar 14, 2007 01:12 AM
