ignition switch
Old Feb 20, 2014 | 12:10 PM
tampatony's Avatar
Default ignition switch
My 2001 camero 3800 appears to be having ig switch issues. When turning the key there is absolutely no response. it's acting as it did last year when the passive anti theft syst malfunctioned. i had to bypass that system and everything was ok until now. The vehicle is parked in the lot at my work and I need to get the vehicle home. What is the procedure to bypass the switch to get it started one more time and how difficult is it since I do not have any tools with me. Thanks in advance for your assistance.
Old Feb 20, 2014 | 01:45 PM
are any lights coming on? are you sure the battery is charged?
Old Feb 20, 2014 | 01:53 PM
frumpy's Avatar
Question
is the security light on again?? if it is try this...Had to do this recently and it worked for me
Insert the key and turn it to Run but don't try to start the engine.
Leave the key on in Run for a minimum of 10 minutes.
Then turn off the key, remove it.
Re-insert it and start the engine.
If that doesn't clear the security light it's worn key tabs, or a BCM issue.
Old Feb 20, 2014 | 01:59 PM
Cheeks's Avatar
August 2011 ROTM
yes, I would definitely check the battery first
Delray Gugle
Apr 7, 2014 07:04 PM
evilmnky45
Jul 31, 2011 05:24 PM
qqqa
Jul 28, 2008 12:27 PM
w0211644
Mar 14, 2007 01:12 AM
muscleman
Mar 6, 2007 11:11 PM
