How to Test for Plugged Catalytic Converter
Old Mar 16, 2014 | 04:54 PM
Default How to Test for Plugged Catalytic Converter
This will be listed in the faq and how to sticky. Thank you Gorn
QUOTE=Gorn;687783 Test for plugged Cat
To test for it you need to remove an o2 sensor and install a pressure gage and measure the back pressure. Anything over 1 PSI is a issue. Yours is most likely 3+ PSI. If you have access to a welder you can drill a 1/4" hole in front of the cat and do the pressure test there. In fact I did one for my neighbor the other day and the 1/4" hole leaked enough he could drive it after.
If you do not want to drill your exhaust
QUOTE
bizarre660
Sep 12, 2012 03:31 PM
EasternStryker
May 9, 2011 05:29 PM
02ssCamaro
Nov 8, 2010 09:26 AM
jxdesign
Mar 7, 2007 06:46 PM
350rs
Jan 9, 2007 06:10 PM
