How to put a toggle switch to the cooling fans
Old Jun 4, 2007 | 11:54 AM
gearyr's Avatar
Default How to put a toggle switch to the cooling fans
I have a 1996 Camaro with a 3.8V6. How do you hook up a toggle switch to turn the cooling fans on when I am stuck intraffic? I am trying to keep the heat down when I am crusing in town. I replaced the thermostat with a 180 degree. I have a coolant leak. It is leaking from the heater hoseat the quick connector. I have tried several things tomake it quit leaking. Had to order the whole heater hose assembly. NOT CHEAP! I ordered from GMParts direct .com Haven't got it yet It cost $84.00+$18.00 shipping. $102.00. Who ever came up with this disign was crazy! They could had it where the 2 heater hoses hook up to the cooling system. That uses 2 pipes that you put the hoses on and use 2 regular clamps. Thanks, gearyr.
Old Jun 4, 2007 | 02:27 PM
Default RE: How to put a toggle switch to the cooling fans
Due to the complicated car wiring, IMO the best thing is to buy a fancontrol kit, and follow the installation instructions. Summit sells a plug and play kit from SLP for around $65. Part # SLE-63011. No splicing or cutting of wires required.
washtubman
82-92 V8 Tech
Mar 11, 2010 07:19 PM
IBCute81
May 18, 2009 07:24 PM
kKkInGsRuLeEe
82-92 V8 Tech
Jul 4, 2008 08:53 PM
usarmyrangrs
Jun 13, 2007 07:34 PM
RyanBumZ28
Feb 9, 2007 11:15 AM
