How do you remove the rear/side quarter panels?
Old Sep 1, 2008 | 04:24 PM
tracy111384's Avatar
Default How do you remove the rear/side quarter panels?
Hi, I need to know how to remove the quarter panels from my '95 z28. I've had some people tell me you drill it through the trunk, others say not to drill. Any help is very appreciated, thanks!
Old Sep 2, 2008 | 02:26 PM
02StanGT's Avatar
Default RE: How do you remove the rear/side quarter panels?
I believe they are welded on there. What are you thinking about drilling?
Old Sep 2, 2008 | 08:17 PM
Plasma torch.
Old Sep 2, 2008 | 10:20 PM
Plasma torch? Why not just a sledge hammer and chisel?
OK, for a serious answer, it sounds like you're wanting to do a panel replacement? You need to find the spot welds at the rolled lip of the fender where it overlaps the main body. You'll see small indentations where the factory welds are. Drill out each spot weld everywhere it's attached to the body. Then you can peel it off. They make handy drill bits made special for drilling spot welds. It has a smaller pilot drill tip and above that has a larger diameter cutting edge so you only drill a large hole in the fender (providing you stop when you cut through the top panel).
Old Sep 2, 2008 | 11:13 PM
Thank you so much for that reply. Exactly what I needed to know, very helpful.
Old Sep 3, 2008 | 12:00 PM
LT1RUNNER's Avatar
ORIGINAL: Camaro 69
learn something new everyday!
Isaac Anthony Ware
May 16, 2012 01:18 PM
daleas88
Sep 3, 2009 10:15 PM
2nd gen year 78'
70-81 V8 Tech
Aug 31, 2009 02:43 PM
tracy111384
Sep 2, 2008 02:24 PM
kerbykk
Mar 1, 2007 11:09 PM
