How can I reprogram the courtesy lights?
Old May 11, 2018 | 03:01 PM
hauler's Avatar
Default How can I reprogram the courtesy lights?
The courtesy lamps in my 2002 stay on for 10 minutes after a door is opened, as it says it should on page 2-61 of the owners manual. with delayed Illumination (pg. 2-62) I should be able to shorten that.
I tried to enter Programming Mode using instructions on page 2-21 in order to turn on Delayed Illumination, but I can't figure out the procedure. To be able to remove the radio fuse (step 4), the door has to be open, which seems to cancel the process. When I turn the key to accessory, I hear no chimes.
How is it done?
Old May 12, 2018 | 01:43 AM
homautomation's Avatar
Want to know how to change the colour of the interior lighting
Old May 12, 2018 | 03:00 PM
hauler's Avatar
No. I want the lights to time out in 25 seconds.
Old Sep 22, 2018 | 09:12 AM
MrsCLyn's Avatar
Did you ever get an answer on how to get into Programming mode? I also am following instructions but I don't get the chimes. I assume there is another step.
Old Sep 22, 2018 | 12:14 PM
hauler's Avatar
Default I gave up
I guess rhe car is old enough to have issues that cost more to get fixed ( by a dealer technician) than they are worth.
duckland23
Aug 16, 2018 08:04 PM
86CamaroZ28
82-92 V8 Tech
Jul 8, 2010 08:20 PM
FR34K
Dec 13, 2007 09:53 PM
Saint_Ali
Dec 9, 2007 05:47 PM
apollo
Oct 24, 2007 01:54 PM
