high idle
Ive had this problem for 6 months now and id like to address the issue. any help will be appreciated
1998 v8 3800 Camaro
5-speed manual
When i start the car it will stall out immediatly unless i give it gas for a few seconds. This happens when i dont drive the car for about 4 hours. Otherwise when i start it, it will shoot up to 2000 rpm and just stay there. Sometimes. It stays at 1000. this will act as the lowest idle unless i shut off the car and turn it back on. I often do this when i drive to reset the idle to 1000. If i accelerate quickly and hit maybe 60 or 70 and pop it in neutral, it will drop to 1000 where it is supposed to be. Sometimes when i coast to a stop light in neutral my rpm's will fluctuate between 2000 and 2200, but when i get below 10mph, it will stay at 2200. Like i said. when she idle's high when im driving, I tend to shut the car off and turn it back on, then the engine idles at 1000. Its very annoying and i dont know how much more my starter can take. There were some days in the summer where it acted perfectly fine with no high idle.
Im thinking maybe a vacume leak, but the lines look hard as hell to get to and i dont have a diagram. Air and feul filter are brand new. i replaced both the TPS and IDLE air contol solinoid on the intake. Check engine light- codes read high idle and TPS read error, even after i replaced the TPS sensor.
I REPLACED CRANK POSITIONING SENSOR AS WELL
check engine light is currently off
so any ideas????
Thanks for the help
1998 v8 3800 Camaro
5-speed manual
so any ideas????
Thanks for the help
