harsh shifting
Old Aug 23, 2010 | 07:35 AM
azndvr's Avatar
Default harsh shifting
I just bought a 98 camaro with 80k miles on it. I start noticing that whenever I put it on drive I can feel the trans grabbing causing the car to shoot forward a little bit even I'm pushing the brakes. And when im driving the shifts from 1 to 2 is more noticeable. I checked the trans fluid and seemed fine. What could be the problem?
Old Aug 23, 2010 | 08:13 AM
what rpm are you idling at? im thinking the accumilator valve may be the issue. go here and about half way down the page at part#18a and 20e. read what its saying. does it match whats goin on with you.
http://www.transmissioncenter.net/4l...rmance%20Parts
Old Aug 23, 2010 | 10:30 AM
azndvr's Avatar
about 1k rpm. its more noticeable when im barely pushing the gas pedal down. I dont know if thats what really happening to me "20e" but i never seen any leaks so far.
Old Aug 24, 2010 | 12:01 PM
that idle seems too high if its at 1000. should be about 750 to 800. have you had it scanned for codes?
Old Aug 26, 2010 | 09:58 PM
azndvr's Avatar
two lines right before 1. so that means its idling around 800~ right? i had it scanned autozone and no codes came up.
Old Aug 26, 2010 | 10:19 PM
thats about right for idle. im still thinkin its a trany problem or maybe torque converter. i would go talk to a good trany shop and see what they say.
Old Aug 26, 2010 | 11:50 PM
Your shooting forward issue would be from having too high of an idle. The noticeable 1-2 shifts might be right, if a previous owner had some special work done to the trans, or even simply installed a Vette servo. The trans in my Vette has a Vette servo (what a coincidence), and the 1-2 shifts are very noticeable and crisp.
Old Aug 27, 2010 | 10:23 PM
azndvr's Avatar
one of the people i talked to said i need an engine bracket. but if its the engine bracket all the shift should be noticeable rather than only 1 - 2 which makes sense about the vette servo. i gotta go under to confirm.
Old Aug 28, 2010 | 12:44 AM
You're not going to know if you have a different servo unless you go through the trouble of removing it so you can compare to a stock one. You're going to need a new o-ring to do that, as you have to destroy the old one to get the servo cover out. But if the servo cover looks nice and clean, and the rest of the trans is all sludged up, you could assume (careful there) the servo may have been changed. Another thought, your 1-2 shifts are "more noticeable". Are they so noticeable that you hear and feel a banging on the floor? That can mean a torn tranny mount letting the tail of the trans lift up and bang on the tunnel.
Old Aug 28, 2010 | 12:51 AM
Chaotic94's Avatar
September 2011 ROTM
I, myself, was thinking it may be a tranny mount.
dooseman
Jan 13, 2012 09:20 PM
WIspartan1026
Jun 22, 2010 06:27 PM
dazed&confused
Nov 28, 2009 03:52 PM
GoofieJ21
Aug 12, 2007 06:38 PM
_mIkE_
Jul 4, 2005 08:12 PM
