LT1/LT4 Tech 1993-1997
1st to 4th shifting
Old Jun 3, 2005 | 02:15 AM
_mIkE_'s Avatar
Default 1st to 4th shifting
Hey all. im brand new to this forum and a starting camaro enthusiast. im in the market for 93 and up z28, but i gotta know if what i've been hearing about this 1st-4th shifting is true about being in all the z28s, and if it is, how much if even possible it would cost to get it takin out. thanks a million
Old Jun 3, 2005 | 02:58 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: 1st to 4th shifting
yes its true its called "skip shift" its basically for gas mileage. its easy to get rid of, its just some sort of plug called a skip shift eliminator, most aftermarket places carry it...jegs, classic industries, etc
Old Jun 3, 2005 | 06:35 PM
JD1969's Avatar
Or you can go to Radio Shack and get a resistor for $.25 and be done with it. I forget what ohn you need but I bet a google search would give you the right answer.
Old Jun 4, 2005 | 12:17 AM
Patrick's Avatar
Administrator
is this resistor a perminant fix or short term?
Old Jun 4, 2005 | 12:53 AM
JD1969's Avatar
Mine has been in for a couple of years, it is the same thing that the places sell, just without the fancy plug. Let me see if I can find the info on it. Go to install documents, then the transmission section look for a mod called !CAGS
http://www.installuniversity.com/ins...sity/index.htm
Old Jul 4, 2005 | 03:08 AM
jtcarguy12's Avatar
it's actually not 1st to fourth it's 1st to 3rd u just tend to pull it in to 4th cause thats the motion. (skip shift. not skip shifts)
Old Jul 4, 2005 | 08:12 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
regardless, it skips 2nd gear, so getting the actual skip shift eliminator would be worth it for this guy
dooseman
Jan 13, 2012 09:20 PM
WIspartan1026
Jun 22, 2010 06:27 PM
dazed&confused
Nov 28, 2009 03:52 PM
c-dub
General Racing/Tech
14
Aug 11, 2009 04:30 PM
GoofieJ21
Aug 12, 2007 06:38 PM
