Grinds when shifting into reverse
ORIGINAL: squisher
Reverse is NOT synchronized. If you stop and then hold the clutch about 5 seconds before shifting it also prevents it from grinding.
The T56 (6 spd on V8s) tranny has a syncro'd reverse, but the T5 (v6 manual) does not. So if there is any movement in the gearbox while trying to shift into reverse, it will grind.
My bad, I had a V8 car in mind.
ORIGINAL: z28pete
You need to replace the reverse gear synchro.
corinnemarie22
03-30-2010 12:02 PM
