Got my car back from Chevy
Old Apr 17, 2008 | 01:12 PM
  #71
Spartan66's Avatar
Default RE: Got my car back from Chevy
ORIGINAL: ninetysixyenko
ORIGINAL: Spartan66
ORIGINAL: dtruck260
Is it possible that you rounded off a lifter?,
A "soft" lifter will cause most of the things you listed without triping a code.
Use a long screwdriver, with the car idling, put the metal tip on the exhaust manifold and the other end to your ear, try to isolate where the sound is coming from.
Check diffrent areas of the engine, you should be able to pin the area down (Top/Bottom/Left/Right/Front/Rear)
(Yardstick works also)
ok ill try that later kuz i have to go to school shortly but ill go listen to it and come back.
it takes 2 min
I have to leave for school in two minutes and dont have time to dig thru my tools for a screw driver lol.
Old Apr 17, 2008 | 01:13 PM
  #72
ninetysixyenko's Avatar
and if it's a spun bearing you should NOT be driving it.. a valve tick wont hurt it to much.
  #73
Spartan66's Avatar
jeez ok! lol hold on ill be right back again. Its coming from the left side if that narrows it down should i just check there?
Old Apr 17, 2008 | 01:14 PM
  #74
Spartan66's Avatar
How do i tell if its a spun bearing?
  #75
start with left, but if you cant find it, go to right also.
Old Apr 17, 2008 | 01:15 PM
  #76
Spartan66's Avatar
ok ill be right back again
Old Apr 17, 2008 | 01:16 PM
  #77
ORIGINAL: Spartan66
someone else should input here, but it will be a real loud "clunk" type of knock from what i understand, and will be heard in upper RPMs(unlike valve tick)
Old Apr 17, 2008 | 01:20 PM
  #78
dtruck260's Avatar
You will know a spun bearing, My bet is Lifter/Valve train.....
(Bearnig going = Loss of oil pressure, hammering at all engine speeds)
  #79
Spartan66's Avatar
ok so its coming from the left rear maybe cylinder 6 or 8 im not sure... im not even sure if its coming from the engine.. it sounded like my engine was underwater when i put my ear on the thing. But its not a knock its a tick. a fast tick.
Old Apr 17, 2008 | 01:21 PM
  #80
Spartan66's Avatar
ORIGINAL: dtruck260
Well the mechanics report from chevy said i had low oilpressure.. and so did the guy i had do the work for me backaround fall.
