Got my car back from Chevy
Old Apr 17, 2008 | 01:05 PM
  #61
ninetysixyenko's Avatar
Default RE: Got my car back from Chevy
ORIGINAL: Spartan66
ORIGINAL: ninetysixyenko
sounds like a warper/bent/bad valve to me. is it more or a ticking?
Well theres a ticking and a knock idk lol.
what do you mean?
  #62
Spartan66's Avatar
yeah. Its a quicker paced tick tick tick tick... ill go out side and listen to the car and come back and tell you what the knock sounds like
  #63
dtruck260's Avatar
Is it possible that you rounded off a lifter?,
A "soft" lifter will cause most of the things you listed without triping a code.
Use a long screwdriver, with the car idling, put the metal tip on the exhaust manifold and the other end to your ear, try to isolate where the sound is coming from.
Check diffrent areas of the engine, you should be able to pin the area down (Top/Bottom/Left/Right/Front/Rear)
(Yardstick works also)
Old Apr 17, 2008 | 01:06 PM
  #64
Spartan66's Avatar
ORIGINAL: Spartan66
what do you mean?
Well i can hear a knock and a tick lol ill go listen hold on.
Old Apr 17, 2008 | 01:07 PM
  #65
Spartan66's Avatar
ORIGINAL: dtruck260
ok ill try that later kuz i have to go to school shortly but ill go listen to it and come back.
Old Apr 17, 2008 | 01:09 PM
  #66
dtruck260's Avatar
Let us know, sounds to me like maybe in the valve train.
Cam/Lifter Change isnt that bad,,,, on the cheap you could even just change out the problem lifter and associated hardware (Pushrod/Rocker/Valve) Though I would not recommend it.
  #67
ORIGINAL: Spartan66
ORIGINAL: Spartan66
what do you mean?
if it's a fast paced tick, and you can hear it @ idle but not with exhaust. my monies on a valve/lifter.
Old Apr 17, 2008 | 01:10 PM
  #68
ORIGINAL: Spartan66
ORIGINAL: dtruck260
it takes 2 min
Old Apr 17, 2008 | 01:11 PM
  #69
Spartan66's Avatar
ok heres the verdict. After listening to it i cant hear a knock.. im assuming a knock would be louder than the tick.. but its a fast paced tick and the engine shakes pretty bad.
Old Apr 17, 2008 | 01:12 PM
  #70
take anything solid. a knife would work.
