gas fumes in car??
i have a 1995 camaro i have had it almost a year. i drove it quite a bit when i first got it and all was good back in july when the weather was hot i drove to the lake about a 45min drive and right before i got there it just shut off coasted to a stop and it did not want to start up acted like it was not getting any fuel finally it started back up.anyways i have let it sit since. i drove it about 20 miles yesterday and about 30 more miles today it ran fine but after about 5 min of driving you can smell gas fumes in the car anyone know what this might be.thanks also its got the 3.4l
smell the oil, see if you have gas in oil? pull the evap vacuum hose and see if you have fuel coming outa there, also do the same to the fuel pressure regulator vacuum hose. be right back.
ok im back. go here and look at number 8 and 25 in particular. https://camaroforums.com/forum/93-02...62/#post557634 lots of other good stuff to look at to. and go here and look at number 33, lots of good info here to. 4th Gen LT1 F-Body Tech Aids
