Question: Exhaust fumes in passenger compartment
Old Feb 22, 2009 | 03:17 PM
Thoreau's Avatar
Default Question: Exhaust fumes in passenger compartment
What should I check if I am trying to rid that damn smell from my car. It was parked for about five years so it has some of that kind of wear on it. I have replaced the exhaust and the fuel tank so it has gotten a little better. Any other suggestions?
Old Feb 22, 2009 | 07:50 PM
johnson73801's Avatar
if you are running mufflers that are close to the floorboard in the rear you might check under the rear seats and see if the isulation is getting hot i had to cut mine out.. i would actually start smoking after it got real warm.
Old Feb 22, 2009 | 07:55 PM
If you're getting fumes inside the car, that means you have holes in the floor, trunk, or firewall where it's getting in. Look for rust holes in the floors, and open access holes in the firewall. Then plug em.
Old Feb 22, 2009 | 10:09 PM
Thoreau's Avatar
Thank you both very much. What do you recommend to plug the holes on the floor, if I have any?
Old Feb 23, 2009 | 11:23 PM
With good metal. First look under the car and see what you can see. From looking at your pics, the car doesn't look like a rust bucket. At least, not in the back.
gofastturnleft70
Sep 9, 2012 11:55 PM
Chaotic94
Jun 20, 2011 06:39 PM
adirtypoostick
Sep 28, 2009 08:39 AM
chadimus06
Sep 25, 2006 02:32 AM
flexnix
Jul 1, 2006 01:58 AM
